Philips 46PFL7605H/12 - audio Transcoding AC3 => MP3
supreme
Post Thu Feb 23, 2012 3:29 pm
I have XviD video, I would like to trancode only the audio AC3 in Mp3.
This script is not worling, I receive an error.
Could you help me? 1000 thanks
<Profile id="2" name="Philips" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>.*PHILIPS.*</FriendlyName>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
      </MediaFormatProfiles>
         <Video targetContainer="mpg" targetACodec="mp3">
            <Matches container="avi" aCodec="ac3"/>
[TV] Philips 46PFL7605H/12 [Wireless USB adapter] Philips PTA01 [Wireless Modem/Router] Netgear DG834GT
Post Thu Feb 23, 2012 3:45 pm
Re: Philips 46PFL7605H/12 - audio Transcoding AC3 => MP3
lets use the correct philips profile as blindly make a new oe is silly
   <Profile id="20" name="Philips" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
         <Video targetContainer="mpeg" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="mp4" />
            <Matches container="mpegts" />
            <Matches container="mpegvideo" />
            <Matches container="asf" />
            <Matches container="ogg" />
            <Matches container="flv" />
            <!-- if audio different to ac3, must be transcoded -->
            <Matches container="mpeg" aCodec="aac" />
            <Matches container="mpeg" aCodec="mp3" />
            <Matches container="mpeg" aCodec="dca" />
         <Video targetContainer="mpeg" targetACodec="ac3">
            <Matches container="avi" />
      <OnlineTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="mp3"/>
            <Matches container="flv"/>
            <Matches container="asf"/>
         </Audio>
      </OnlineTranscoding>
sorted.
supreme
Post Thu Feb 23, 2012 4:17 pm
You have right, but what I am looking for is a script that transcode all the video with audio AC3 in MP3. The reason is that in ac3 my video is start and stop.
Post Thu Feb 23, 2012 4:22 pm
All video !!?
So replace all targetACodec="ac3" by targetACodec="mp3" in the Philips profile section.
Post Thu Feb 23, 2012 4:23 pm
ok im confused that dont make sense if you mean AVI with ac3 to mp3 you cant but u can just remux it to mpeg.
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
      <OnlineTranscoding>
         </Audio>
supreme
Post Thu Feb 23, 2012 4:34 pm
Yes video AVI - AC3 converted in AVI - MP3 why is not possible? With converter software like AVS Converter I can do it.
What I don't know if I have to transcode also the video or only the audio...
Post Thu Feb 23, 2012 4:39 pm
supreme wrote:
Cerberus wrote:ok im confused that dont make sense if you mean AVI with ac3 to mp3 you cant but u can just remux it to mpeg.
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
      <OnlineTranscoding>
         </Audio>
Because when u transcode it you can it to mpeg container and u cant have ac3 inside mpeg container as its not supported by the device. Thats why i added this section to the profile to solve your problem
supreme
Post Thu Feb 23, 2012 5:07 pm
With your script i hear the sound but black screen, I see in the temporary folder the transcode file: "transcoding-temp-604-MPEG2PS.stf"
C:\tmp\4sat\transcoding-temp-604-MPEG2PS.mpg
      Complete name : C:\tmp\4sat\transcoding-temp-604-MPEG2PS.mpg
      Format : MPEG-PS
      File size : 707 MiB
      Duration : 56mn 5s
      Overall bit rate : 1 762 Kbps
      Writing library : XviD0050
   Video #224
      Format : MPEG-4 Visual
      Format profile : Advanced Simple@L5
      Format settings, BVOP : Yes
      Format settings, QPel : No
      Format settings, GMC : No warppoints
      Duration : 56mn 4s
      Bit rate : 1 279 Kbps
      Width : 608 pixels
      Height : 256 pixels
      Display aspect ratio : 2.40:1
      Frame rate : 23.976 fps
      Color space : YUV
      Chroma subsampling : 4:2:0
      Bit depth : 8 bits
      Scan type : Progressive
      Compression mode : Lossy
      Bits/(Pixel*Frame) : 0.343
      Stream size : 513 MiB (73%)
      Writing library : XviD 1.2.1 (UTC 2008-12-04)
   Audio #189-128
      ID : 189 (0xBD)-128 (0x80)
      Format : AC-3
      Format/Info : Audio Coding 3
      Muxing mode : DVD-Video
      Duration : 56mn 5s
      Bit rate mode : Constant
      Bit rate : 448 Kbps
      Channel(s) : 6 channels
      Sampling rate : 48.0 KHz
      Bit depth : 16 bits
      Delay relative to video : -270ms
      Stream size : 180 MiB (25%)
What I have to do?
Post Thu Feb 23, 2012 7:28 pm
MPEG-4 Visual Video codec remuxed into MPEG-PS is not supported by Philips TV (and all devices...its not a standard). (MPEG-TS too).
You have to transcode the video to MPEG2VIDEO.
In fact, if you have to remux an AVI file, you should transcode the video codec.
Because the targetContainer supported by serviio are MPEGPS, MPEGTS, ASF.....AVI, MKV or MP4 target container are not supported.
try this:
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
      <OnlineTranscoding>
         </Audio>
@illico u was 2 clicks ahead of me ;)
supreme
Post Fri Feb 24, 2012 9:21 am
I want to thank Cerberus and Illico for the fast help. Now I will try your script Cerberus and I will write the result.
So I see that future release of Serviio can be upgradeted to support AVI, MKV or MP4 target container.
Post Fri Feb 24, 2012 10:38 am
supreme wrote:So I see that future release of Serviio can be upgradeted to support AVI, MKV or MP4 target container.
Not sure, AVI, MKV and MP4 target container are not adapted for streaming (there where some information at the end of file for example)
supreme
Post Sat Feb 25, 2012 8:59 am
Cerberus your last script is not working, still the video is stop and go. My original video is XviD - AC3
Here you can see the file generated by the transcoding:
C:\Windows\Temp\Serviio\transcoding-temp-604-MPEG2PS.stf
      Complete name : C:\Windows\Temp\Serviio\transcoding-temp-604-MPEG2PS.stf
      Format : MPEG-PS
      File size : 882 MiB
      Duration : 56mn 5s
      Overall bit rate : 2 199 Kbps
   Video #224
      Format : MPEG Video
      Format version : Version 2
      Format profile : Main@Main
      Format settings, BVOP : No
      Format settings, GOP : M=1, N=15
      Duration : 56mn 5s
      Bit rate mode : Variable
      Bit rate : 1 707 Kbps
      Width : 608 pixels
      Height : 256 pixels
      Color space : YUV
      Bit depth : 8 bits
      Bits/(Pixel*Frame) : 0.457
      Stream size : 685 MiB (78%)
   Audio #189-128
      Format : AC-3
      Duration : 56mn 5s
      Bit rate : 448 Kbps
      Bit depth : 16 bits
      Delay relative to video : 64ms
      Stream size : 180 MiB (20%)
Still I see that the audio is AC3, but I need that is MP3...
Post Sat Feb 25, 2012 9:46 am
you can not have it as mp3 its NOT supported.
supreme
Post Sat Feb 25, 2012 9:54 am
Cerberus wrote:you can not have it as mp3 its NOT supported.
Which other codec audio is supported? For my television AC3 is not good, so I have to put another audio...
Post Sat Feb 25, 2012 10:02 am
no ac3 is fine, and the only supported audio codec, try this.
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
      <OnlineTranscoding>
         </Audio>
supreme
Post Sat Feb 25, 2012 10:32 am
Cerberus wrote:no ac3 is fine, and the only supported audio codec,
Could be I have to reduce the channels audio and the bitrate? Which is the value I can put in the script?
Post Sat Feb 25, 2012 10:59 am
just try the profile i posted above.
supreme
Post Sun Feb 26, 2012 11:58 am
No you profile is nor worlking the video start and after 2 seconds stop and go and black screen.
I was put this new line in the script to force the transcoded video to be a 2 channel stereo, but how you can see in the transcode file: "transcoding-temp-604-MPEG2PS.stf" the audio channels are still 6, the bitrate 448 Kbps
 <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" aSamplerate="44000" forceStereo="true">
      Format : MPEG-PS
      File size : 633 MiB
      Duration : 56mn 5s
      Overall bit rate : 1 577 Kbps
   Video #224
      Format : MPEG Video
      Duration : 56mn 5s
      Bit rate : 1 098 Kbps
      Width : 608 pixels
      Height : 256 pixels
      Color space : YUV
      Bit depth : 8 bits
      Bits/(Pixel*Frame) : 0.294
      Stream size : 440 MiB (70%)
   Audio #189-128
      Format : AC-3
      Duration : 56mn 5s
      Bit rate : 448 Kbps
      Bit depth : 16 bits
      Stream size : 180 MiB (28%)
Post Sun Feb 26, 2012 12:08 pm
supreme wrote:I was put this new line in the script to force the transcoded video to be a 2 channel stereo, but how you can see in the transcode file: "transcoding-temp-604-MPEG2PS.stf" the audio channels are still 6, the bitrate 448 Kbps
Check your detailed logging file and found the ffmpeg command line used to transcoded this file.
Then try locally the same command line in a windows terminal. Check the ffmpeg process, you will probably find the reason why ffmpeg does not force to stereo...
Return to Philips
